Tilt Derivative giving an error
Hello! I'm a new user to Oasis. I have a TMI TIFF (I don't have raw data, but TIFF, TFW and ISI Common Export in a folder) that I imported into oasis. I managed to apply the correct coordinate and area (size), the went on to do 1DV, then smoothed the 1DV using the 3X3 Symmetric Convolution. It all worked until this point. After this I then went ahead to do a Tilt Derivative, as I would like to get my structural readings at depth and export them for Leapfrog 3D modeling. Is there anything I am doing wrong? Your assistance is highly appreciated.
  • FarzanehFarahani1
    FarzanehFarahani1 Employee Posts: 21 mod
    Hi @NelaoNaimbale ,
    Thank you for your interest and reaching out. It seems the grid you are working with is a colour grid. Can you please try using the Grid and Image > Utilities > Copy/Convert Grid(s) menu option and convert your grid to a Geosoft Grid? This should solve the issue.
    Regards,
    Farzaneh Farahani
    Technical Solutions Specialist, Geophysicist
  • @Farzaneh Farahani, converting the tiff to a geosoft grid is the first thing I did. Then I went past 1DV without a problem. Its the Tilt Derivative that kept giving that error. I even tried using the colour tool to generate a new map, using the histogram equalization and it still did not work. I ended up using 2D filtering, then butterworth filter; that way it ended up generating the Tilt derivative grid and then map. Then I extracted the structures as csv for leapfrog use. Would that be a workable choice for realiable results?
    Thank you again
  • CatherineMichibi
    CatherineMichibi Unconfirmed Posts: 2 New Member
    how did you convert a tiff to a geosoft grid?
  • I imported it via
    (1) Grid and Image > Display on Map > Image (bmp, tiff etc)
    (2) Then went back to Grid and Image > Utilities > Copy/Convert Grids (Input: TMI Tiff, output: TMI.grd, output format: Geosoft float (*.grd)
    I don't have raw data, hence, I went that route. The tiff is provided together with a TFW, which I guess make the tiff compatible for upload into Oasis.
    Happy to hear any suggestion or better way to work around images.
  • In this case especially you have a .tiff image, you ay insert it to another software like surfer or another one that can export the image into an .xyz or .txt file or any format containing the long, lat, and the variable z file. After that, you can import this file to a new database in oasis montaj and start your workflow again. Try this if possible and tell me the result, we will try until we get a solution Inshaa Allah.
  • Hello Ibrahim,
    Thank you for your kind response. I actually, didn't think of it. But I will try it and see if it works.
    However, I ended up going to the relevant people and kindly requesting for a grid file instead, which, they fortunately provided. So I managed to get on with my work then.
    But I will try the process you mentioned. It might help me in some way one good day.
    Kind regards,
    Nelao
