Time-lapse inversion in RES2DINV – Using T0 baseline model as initial model for T+1 inversion?
Hello everyone,
I would like to perform a time-lapse data inversion using the double difference method described by Bretaudeau et al. 2021 (https://doi.org/10.1093/gji/ggab172) with RES2DINV.
To do this, I would like to import the resistivity model from the T0 (baseline) data inversion as the initial model for the T+1 data inversion. Is this possible with RES2DINV? If so, how?
Thank you in advance.
Angélie.
  • Hi Angélie
    Unfortunately, it is not possible in RES2DINV to import the inversion result from the baseline survey (T0) as the starting model for the inversion of a later time step (T+1).
    However, it is worth noting that the time-lapse inversion in RES2DINV already links the datasets together by default. The inversion is therefore not performed completely independently for each time step. Instead, the time-lapse algorithm is designed to highlight changes relative to the baseline model while maintaining consistency between the models.
    Depending on your specific objective, it may be possible to achieve a similar effect by using fixed regions or other model constraints, although this would not be equivalent to directly using the T0 inversion result as the starting model for T+1, and to be honest we are not sure how well it will actually work.
