Creating a contact surface from an open mesh
MasopGasty
in Leapfrog
- How do I create a surface contact from an open mesh to obtain the output volume that is similar to the shape of the mesh being used?
- What is the correct surface type to use?
1
you can create either an Erosion or Deposit surface from the mesh within a geological model. what geological contact type does the open mesh represent?
1 -
These are meshes of veins/mineralized zones. They come as open or partially closed segment.
I had no issue modelling the closed meshes as intrusive surfaces. But the open ones are producing strange surfaces. see images attached
Thankyou
1 -
It's a little difficult to see what's happening in your pictures, but if you have separate objects representing vein footwall and hangingwall surfaces it would be possible to use them as top/bottom contacts of a 'stratigraphic' unit. What is your objective in creating leapfrog volumes from these shapes? Are you trying to make new Leapfrog model objects?
