I need a help from all the experts here. My slicer width is set to 1 but the scene is not showing as it should have been. Any help please ??
ManaskaMukhopadhyay
Unconfirmed Posts: 2
in Leapfrog
Best Answer
Check your drillhole coordinates - this usually happens when you have data spread over too great an area. The usual suspect is an issue in the collar file with a zero or typo in the X or Y causing the project working area to be significantly large.
2
@ShaunNeal1 Thank you.. It worked…
1
Categories
- All Categories
- 6 Community
- 3 Get Started
- 16 Latest Releases
- 15 Member Spotlight
- 40 Learning
- 2 Products
- 1 Geology
- 535 Leapfrog
- 1 Volsung
- 26 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- Geotechnical
- 136 GeoStudio
- Geophysics
- 319 Oasis montaj
- 1 Workbench
- SPIA
- 9 Res2DInv & Res3DInv
- 3 Evo
- 26 GX Developer
