I need a help from all the experts here. My slicer width is set to 1 but the scene is not showing as it should have been. Any help please ??
ManaskaMukhopadhyay
Unconfirmed Posts: 2
in Leapfrog
Best Answer
Check your drillhole coordinates - this usually happens when you have data spread over too great an area. The usual suspect is an issue in the collar file with a zero or typo in the X or Y causing the project working area to be significantly large.
2
@ShaunNeal1 Thank you.. It worked…
1
Categories
- All Categories
- 311 Community
- 3 Get Started
- 18 Latest Releases
- 17 Member Spotlight
- 42 Learning
- 1.1K Products
- 567 Geology
- 540 Leapfrog
- 1 Volsung
- 26 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- 138 Geotechnical
- 138 GeoStudio
- 334 Geophysics
- 323 Oasis montaj
- 1 Workbench
- SPIA
- 10 Res2DInv & Res3DInv
- 3 Evo
- 27 GX Developer
