Master the Subsurface – Structural Modelling Challenge: Put what you’ve learnt into practice!
BeckyBodger2
Employee Posts: 17 mod
It’s challenge time again! After today’s Oasis montaj Mastery Session, please take part in our ‘Master the Subsurface’ challenge.
The rules are simple, but the possibilities are endless. Build a structurally complex, geologically sound, 3D model and test its geophysical signature.
Here’s how to enter:
- Download the demo data: Download the Oasis montaj project file here: Cornwall Forward Model.gpf contains both the Master Voxel and the survey path database.
- Build the 3D structural model: Create your structural model (representing faults, intrusions, and geological bodies) using the provided equations. Note: Use the Master Voxel as your building base.
- Run VOXI forward modelling: Open the provided VOXI project, load your newly built model as the “Starting Model”, and click “Run Forward Model”.
- Share your final results in the comments below!
Remember, Forward Modelling with VOXI is completely free and does not require a separate VOXI subscription.
In the first comment below is a Quick Reference Guide containing equations to support you to build a starting model for forward modelling in VOXI.
We’re looking forward to seeing your complex forward models! The first 10 posted below will win Seequent merchandise packs!
Categories
- All Categories
- 307 Community
- 17 Latest Releases
- 17 Member Spotlight
- 1.1K Products
- 567 Geology
- 540 Leapfrog
- 1 Volsung
- 26 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- 137 Geotechnical
- 137 GeoStudio
- 332 Geophysics
- 321 Oasis montaj
- 1 Workbench
- SPIA
- 10 Res2DInv & Res3DInv
- 3 Evo
- 27 GX Developer
