One Continuous Long Section from Segments
If I understand the question properly, it would seem possible to simply export the polyline segments and combine them in a text editor and re-import the combined polyline into LF. Polylines are just a series of points which can be edited and combined in any text editor. As far as I know there is not a method to combine lines inside LF. Good luck.
0 -
Thank you Thomas for your answer. Right, seems there is no method in combine lines inside LF except your method or redraw it as one polyline.
