One Continuous Long Section from Segments
Hi All, I would like to create continuous section from a polyline. Nevertheless, the polyline is composed of segment that lead to sections in segments created. Is there a way to combine to segment into one polyline or make a section from multiple segments? Thank you.
If I understand the question properly, it would seem possible to simply export the polyline segments and combine them in a text editor and re-import the combined polyline into LF. Polylines are just a series of points which can be edited and combined in any text editor. As far as I know there is not a method to combine lines inside LF. Good luck.
Thank you Thomas for your answer. Right, seems there is no method in combine lines inside LF except your method or redraw it as one polyline.
- 5 Community
- 15 Member Spotlight
- 39 Learning
- 2 Products
- 1 Geology
- 535 Leapfrog
- Geotechnical
- Geophysics
- 319 Oasis montaj
- 9 Res2DInv & Res3DInv
- 26 GX Developer
