One Continuous Long Section from Segments
Hi All, I would like to create continuous section from a polyline. Nevertheless, the polyline is composed of segment that lead to sections in segments created. Is there a way to combine to segment into one polyline or make a section from multiple segments? Thank you.
If I understand the question properly, it would seem possible to simply export the polyline segments and combine them in a text editor and re-import the combined polyline into LF. Polylines are just a series of points which can be edited and combined in any text editor. As far as I know there is not a method to combine lines inside LF. Good luck.
0 -
Thank you Thomas for your answer. Right, seems there is no method in combine lines inside LF except your method or redraw it as one polyline.
Categories
- All Categories
- 311 Community
- 3 Get Started
- 18 Latest Releases
- 17 Member Spotlight
- 42 Learning
- 1.1K Products
- 567 Geology
- 540 Leapfrog
- 1 Volsung
- 26 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- 138 Geotechnical
- 138 GeoStudio
- 334 Geophysics
- 323 Oasis montaj
- 1 Workbench
- SPIA
- 10 Res2DInv & Res3DInv
- 3 Evo
- 27 GX Developer
