can we filter a block model with a surface?
BryanVillahermosa
in Leapfrog
i would like to find out how many blocks of a block model is above surfaces such as pit shells and/or topography. how can we do this in leapfrog?
Best Answer
You could also try using the Grouped Mesh functionality (accessible via the combined model folder).
From Leapfrog 2023.1 onwards, you can use an open mesh as the basis for a grouped mesh. This means that you can use your open mesh and evaluate either Above or Below the mesh with a category of your choosing.
Once you have evaluated the grouped mesh into your Block Model you can then select it as a display and turn off/on different blocks, use the display filter or create a Query Filter.
Hopefully that helps!
Cheers,
Joseph
Categories
- All Categories
- Community
- 16 Latest Releases
- 15 Member Spotlight
- 38 Learning
- Products
- Geology
- 535 Leapfrog
- 1 Volsung
- 25 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- Geotechnical
- 136 GeoStudio
- Geophysics
- 319 Oasis montaj
- 1 Workbench
- SPIA
- 9 Res2DInv & Res3DInv
- 3 Evo
- 25 GX Developer
