Any good way to model the looped fault junction?
Dear all,
Is there any way that I can map a fault system that has multiple faults terminating on each other? I think Leapfrog Geo can only let older fault terminate on younger fault?
Please see the following figure. In this case, I have faults that were terminating on each other, based on previous mapping. I cannot model them in Leapfrog Geo because I cannot match that only older faults terminate on younger faults.
Is there a good way to model this kind of fault system? Thanks!
Hi
In this situation you are describing the workflow shown here may help: MySeequent
This shows how to turn faults into finite faults which may work with the example you are describing.
Hope that helps
Regards
Keith
