Copy data from one project to another
Dear all,
Is it possible to copy the imported item in the project tree of a project A, and paste the item into a project B? I have some shapefiles and wells with edit color-code in a project A, and I would like them to be presented the same in a project B. Is it possible?
In addition, is it possible to open 2 projects at the same time?
Thanks!
Thanks!
Best Answer
You are correct. Saving the .lfc (Leapfrog Color File) is the way to share those color maps to match in other projects.
To your second question. Is is not possible to have two projects open at the same time.
Cheers,
Sean0
Kinda found the answer for the first part of my own question. The color code can be exported as a .lfc file, and then be imported into another project if the file can match the .lfc file.
For question 2, I still not sure if it is possible0
Categories
- All Categories
- 311 Community
- 3 Get Started
- 18 Latest Releases
- 17 Member Spotlight
- 42 Learning
- 1.1K Products
- 567 Geology
- 540 Leapfrog
- 1 Volsung
- 26 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- 138 Geotechnical
- 138 GeoStudio
- 334 Geophysics
- 323 Oasis montaj
- 1 Workbench
- SPIA
- 10 Res2DInv & Res3DInv
- 3 Evo
- 27 GX Developer
