Is it possible to export cross section to FEM software such as Plaxis.
KeivinNikolli
in Leapfrog
Hello,
I am trying to export cross-sections generated by LeapfrogWorks into Plaxis 2D. I have evaluated the objects on my cross-section and I noticed that when I export them as .dfx, separate files are created and none of these files was able to be used in Plaxis 2D.
I hope somebody might have an answer or a guideline on how can I solve this problem.
All best,
Keivin
All best,
Keivin
Interested to know the process others may have to do this too0
This seems to be still a open problem. I put a support-request because we want to use Leapfrog-model in Plaxis 3D.0
Hi All,
Cross sections can be exported from Leapfrog to Plaxis 2D in a dxf format. When exporting from Leapfrog you need to use the 2D Analysis Tab in the export sections dialogue to translate the section to a 0,0 origin and also simplify the line work.
Some software such as GeoStudio allows you to do the translation and simplification on import. In those cases, it is preferable to use the software's tools as it can make it easier when exporting results back to Leapfrog for visulisation. GeoStudio will reapply the same translation to any tiffs exported so that they are in the same 3D space.
Simplification sets a minimum allowable distance between nodes along the volume outlines. Increasing the Minimum spacing setting reduces the number of nodes included but can result in loss of detail.
Each Leapfrog model or surface evaluation will be exported as a separate dxf file and can be renamed in the General tab.
If you have any pain points with your workflow when importing to Plaxis 2D, please reach out to Seequent Support.
Thanks,
Richard1
Categories
- All Categories
- 311 Community
- 3 Get Started
- 18 Latest Releases
- 17 Member Spotlight
- 42 Learning
- 1.1K Products
- 567 Geology
- 540 Leapfrog
- 1 Volsung
- 26 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- 138 Geotechnical
- 138 GeoStudio
- 334 Geophysics
- 323 Oasis montaj
- 1 Workbench
- SPIA
- 10 Res2DInv & Res3DInv
- 3 Evo
- 27 GX Developer
