Is it possible to create a cubic slice?
JamesBlack
Posts: 3 New Member
in Leapfrog
Hi,
I was wondering if there is a way to have 2 slices active at the same time, to cut a cube shape out of my ground model to show the geology in a specific area of the model.
Thanks in advance
Thanks in advance
1
@JamesBlack,
You can't have two active slices at the same time, but as a work around you could try a few possible work arounds:
- Evaluate your GM onto a block model and use the index filters to create a subset / sliced block model (dynamic slicing).
- Make a copy of your GM and add a lateral extent to its boundary using a polyline based on the area that you want to remove (limited to a single prechosen slice).
I hope that helps, Cheers
David
Categories
- All Categories
- 311 Community
- 3 Get Started
- 18 Latest Releases
- 17 Member Spotlight
- 42 Learning
- 1.1K Products
- 567 Geology
- 540 Leapfrog
- 1 Volsung
- 26 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- 138 Geotechnical
- 138 GeoStudio
- 334 Geophysics
- 323 Oasis montaj
- 1 Workbench
- SPIA
- 10 Res2DInv & Res3DInv
- 3 Evo
- 27 GX Developer
