Importing cross sections into LF geothermal
Options
MadisonMacKenzie
in Leapfrog
I am trying to upload cross section PNG images into my model, but I keep getting this error. My cross section runs E-W which inherently means that its on the same North line, but leapfrog won't process my image if there are any duplicate XYZ coordinates. How do I import an E-W cross section into my landscape?
Hi Madison,
You will also need to add in the elevation of the two reference markers and make sure that they are not at the same elevation, then it should work. See my example below.
Regards,
David1
