Dynamically link Planned Drillholes to a mesh/output volume
Hi all,
Is there a way to dynamically link planned drill holes to a mesh so that every time the mesh is updated the target depths of the planned drill holes are updated as well?
I have a lot of planned drill holes that target a particular mesh which is regularly updated. It gets quite tedious to re-adjust the planned drill holes every time it is updated.
Alternatively, are they any workarounds to this problem that can help streamline the process.
Any thoughts are highly appreciated.
Regards,
James.
Hi James,
Thanks for your feedback, I will add it to our feature requests list.
Regards,
David0 -
Hi James,
One alternative would be to set an evaluation from your geological model. This would be updated every time the wireframe is. You could them export and check new intervals as you go.
But for that, you’d need to guarantee that your planned ddh crosses the entire wireframe.Cheers.
Dhaniel Carvalho0
Categories
- All Categories
- 311 Community
- 3 Get Started
- 18 Latest Releases
- 17 Member Spotlight
- 42 Learning
- 1.1K Products
- 567 Geology
- 540 Leapfrog
- 1 Volsung
- 26 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- 138 Geotechnical
- 138 GeoStudio
- 334 Geophysics
- 323 Oasis montaj
- 1 Workbench
- SPIA
- 10 Res2DInv & Res3DInv
- 3 Evo
- 27 GX Developer
