Looking for workflow on overburden/bedrock constraint for MVI inversion
ToddBallantyne
in Oasis montaj
Is there any documentation on setting up vector voxel constraints for MVI? The help documentation mentions it, but I'm having little success finding discussions of it. I have a bedrock surface and would like to ensure that the MVI results are confined to the bedrock as can readily be done in susceptibility models. Is this possible?
When trying to build a model from the input vector voxel the constraint type no longer allows upper bound. I'm assuming then that a parameter reference model is to be used. I'm not clear how to define above and below the surface.
Todd
Todd
1
Thank you very much Taronish!0
Categories
- All Categories
- 311 Community
- 3 Get Started
- 18 Latest Releases
- 17 Member Spotlight
- 42 Learning
- 1.1K Products
- 567 Geology
- 540 Leapfrog
- 1 Volsung
- 26 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- 138 Geotechnical
- 138 GeoStudio
- 334 Geophysics
- 323 Oasis montaj
- 1 Workbench
- SPIA
- 10 Res2DInv & Res3DInv
- 3 Evo
- 27 GX Developer
