What is the correct way to use gdb extent_xyz()
RichardScott
in Oasis montaj
Best Answers
Hi @RichardScott, can you try signing out of My Geosoft (hover over your name in the top right hand corner and click sign out), then sign back in? Also can you let me know which web browser you are using and the version?5
Yes, that worked. Thanks!0
Hi @RichardScott we have a GX Developer Forum that would be better suited to answer your question. You are signed up for it automatically when you download the latest version of GX Developer here.
You may be using a version of GX Developer that pre-dates the forum. Downloading a more recent version will get you access to the GX Developer Forum where you can re-post your question.0 -
Thanks!0
I registered, but accessing the forums :- Permission Problem
You don't have permission to do that.0 -
GX Developer Registration Confirmation
Hello Richard
Thank you for registering as a GX Developer.
You have been registered as a participant in the GX Developer Community Forum.
Complete documentation is available online: GX Developer documentation.
Geosoft GX Development Team
0 -
Hi @RichardScott What happens if you click this link:
https://my.geosoft.com/forum#/categories/gx-developer
Do you get the same error? I double checked and you should definitely have access to the GX Developer Forum now.0 -
Same error, sorry.0
Categories
- All Categories
- 302 Community
- 3 Get Started
- 17 Latest Releases
- 16 Member Spotlight
- 42 Learning
- 1.1K Products
- 565 Geology
- 538 Leapfrog
- 1 Volsung
- 26 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- 137 Geotechnical
- 137 GeoStudio
- 332 Geophysics
- 321 Oasis montaj
- 1 Workbench
- SPIA
- 10 Res2DInv & Res3DInv
- 3 Evo
- 27 GX Developer
