How to delete multiple samples using import in MX Deposit
NimbusInsights
in MX Deposit
Hi everyone, does anyone know how to delete multiple samples at once using the import/export function in MX Deposit?
@GrahamAndrews @RichardMillington do any of you know how to do this in MX?
Hi, it can't be done through the import/export function. You can delete data in columns that are non-mandatory using this workflow.
To bulk delete all sampling data, you will need to contact support@seequent.com. If it's only a couple of holes' worth of data, I would suggest the classic select the rows and delete.
2
- 6 Community
- 15 Member Spotlight
- 40 Learning
- 2 Products
- 1 Geology
- 535 Leapfrog
- Geotechnical
- Geophysics
- 319 Oasis montaj
- 9 Res2DInv & Res3DInv
- 26 GX Developer
