Convert a calculated variable to a alpha / category
I am trying to apply a bench code to a block model using this function
Bench = round(([zc]-[Block Model Z origin])/ [Bench Height],0)* [Bench Height] +[Block Model Z origin]
Broadly the calc is doing what is needs (although not having the INT() option is a challenge)
However, I need to report from the model on the Bench coding and since the model is quite large I don't want to have to code in a category field with 100 If statements to make the bench category file
So, crux of the matter - does anyone know how the blazes to convert a numeric to a alpha in the calculations option of a model in leapfrog Geo 2025.1.0
Hi Justin,
Due to the nature of converting 'continuous data' to finite 'category data' a direct grouping has always needed that manual step. The standard method works for most scenarios but RL flagging has always been the biggest pain. As I also am not a fan of unnecessary manual entry, I've created a workflow to use numeric distance buffers and grouped meshes. I'll attach the doc here and hope it helps you get the output you need!
Cheers, Lee
Lee Evans
Project Geologist, Seequent, APAC
- 288 Community
