Some questions about the Distance Function Object
YuTingYu
YuTingYu Posts: 16
I am using the Distance Function to create a block model from my fault system.
Please refer one of my previous question: https://community.seequent.com/discussion/1995/is-it-possible-to-export-a-mesh-to-a-block-model#latest
1) If I have multiple objects considered in Distance Function. Am I correct that the number I see in the end is the distance to the closest object?
2) Is is correct that Distance Function can not create a numeric model that consider the topography in the model? I tried to create the block model based on the Distance Function but it was providing a block model including the blocks above the ground.
Thanks for the answering!
