Error with GXC Version 2026.1 (20260610.24)
BenoitTournerie
in GX Developer
I have set of GX's - all compiled correctly using latest Geosoft Desktop, but I have a strange error on using GXC with the new version -
no issue on using first GRC (as "grc example.grc"), but on step 2: GXC ("gxc example.gxc") reports an error [Unable to run the Geosoft Preproccesor (GPP.EXE).] and just display the help of GPP(?)
Any idea of the issue?
@SandTeam @BAYEGUIIgor @TimNixon1 tagging you in case you’ve come across this before.. any ideas on what might be causing the GXC/GPP error with 2026.1? Appreciate any insight!
0 -
This issue will be addressed in the next release. In the meanwhile the workaround is to downgrade to 2025.2.1.
0 -
thanks for the info.
Categories
- All Categories
- 9 Community
- 3 Get Started
- 16 Latest Releases
- 15 Member Spotlight
- 42 Learning
- 7 Products
- 2 Geology
- 536 Leapfrog
- 1 Volsung
- 26 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- Geotechnical
- 136 GeoStudio
- 3 Geophysics
- 321 Oasis montaj
- 1 Workbench
- SPIA
- 10 Res2DInv & Res3DInv
- 3 Evo
- 27 GX Developer
