Hi Team, does anyone know how I can combine two separate projects into one using Leapfrog Geo?
DaubaDauba
Unconfirmed Posts: 3 New Member
Also, if there is a way around which I can import a geological model built on a different project into another project? I have tried but only can import as a mesh and does not import under Geological Models in the project tree. Appreciate your feedback if any.
0 -
Hi,
I’ve never tried it. But given the way Leapfrog builds a geological model, I don’t think it’s possible at the moment. For more you can read this :
Converting static meshes into dynamic Leapfrog models - Seequent
Regards
1 -
Hi Francois, thank you for your feedback. I think that should be a made possible with Leapfrog Geo so that it will be easy for users. I will check out the link sent through as well. Cheers!
Categories
- All Categories
- 302 Community
- 3 Get Started
- 17 Latest Releases
- 16 Member Spotlight
- 42 Learning
- 1.1K Products
- 565 Geology
- 538 Leapfrog
- 1 Volsung
- 26 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- 137 Geotechnical
- 137 GeoStudio
- 332 Geophysics
- 321 Oasis montaj
- 1 Workbench
- SPIA
- 10 Res2DInv & Res3DInv
- 3 Evo
- 27 GX Developer
