Dublicate/copy a single cell from one table to another
Hi there!
I am currently using MX Deposit for field mapping, and while setting it up, I have decided to separate a couple of tables, such as alteration and structural measurements.
Ideally, I want the UTM, Easting, and Northing to duplicate what was written in my main table, "Lithology description," every time I fill in the "station ID" tab, which would correlate with the main "lithology description" table, so I can easily download it and put it into QGIS instead of faffing around with the coordinates later.
I feel like I was close to discovering it by using the formula feature and then the "External input," but it seems to only take the whole column, not the single cell on the same row with the corresponding "station ID".
Any advice?
  • PrachiChitkara
    PrachiChitkara Posts: 465 admin
    edited July 15
    Hi @JasminTordenro I checked with the seequent tech team - and they might need to investigate more. Can you share this on support@seequent.com and they will look into this specific one for you
