When exporting sections, how do I export borehole lines/paths with the model (dwg)?
RobertMillar
Unconfirmed Posts: 1 New Member
in Leapfrog
Hello,
My goal is to export the cross sections to dwg for engineers to bring into the CAD drawings. When I export the sections, only the block models are created. How can I retain the borehole paths with the model in dwg? Attached are figures depicting the dwg and section.
Thanks!
Although it may not be a real solution for the issue you are facing, if you export only the well traces of the profile as a tiff file, they will plot in the correct coordinates. The only thing is that the traces are not editable like a .dwg file would be.
1 -
Under the Boreholes folder you are able to export the polylines as a dxf this can then be imported to your CAD environment to show the traces
2
Categories
- All Categories
- 311 Community
- 3 Get Started
- 18 Latest Releases
- 17 Member Spotlight
- 42 Learning
- 1.1K Products
- 567 Geology
- 540 Leapfrog
- 1 Volsung
- 26 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- 138 Geotechnical
- 138 GeoStudio
- 334 Geophysics
- 323 Oasis montaj
- 1 Workbench
- SPIA
- 10 Res2DInv & Res3DInv
- 3 Evo
- 27 GX Developer
