Is there an up-to-date document detailing how to apply magnetic base station corrections to surveys?
MitchelHezel
Posts: 1 New Member
in Oasis montaj
I can't seem to find a document that explains how one goes about applying a base station correction to a magnetic UAV survey.
I have an excel file with raw recorded base station values and the time the values were collected (in Unix time). I also have a database with the survey data and the time of collection (also in Unix).
There are documents online and on the Seequent site that explain how you might do this, but they all either seem to reference a version of Oasis Montaj which has since been updated, or they require me to basically know what formula ought to be used to apply a base station correction, which is part of the reason I'm using Oasis Montaj in the first place (because I don't know exactly how it should be done, and I expect the correct approach is pretty universal in magnetic surveying).
1
Hi Mitchel, I'm having the same problem. Have you found a solution? Could you share it? I would be extremely grateful.
0 -
Hi, Gustavo. Have you tried to follow the steps explained in this link? It is specific for the tool of the UAV extension.
1
Categories
- All Categories
- 311 Community
- 3 Get Started
- 18 Latest Releases
- 17 Member Spotlight
- 42 Learning
- 1.1K Products
- 567 Geology
- 540 Leapfrog
- 1 Volsung
- 26 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- 138 Geotechnical
- 138 GeoStudio
- 334 Geophysics
- 323 Oasis montaj
- 1 Workbench
- SPIA
- 10 Res2DInv & Res3DInv
- 3 Evo
- 27 GX Developer
