Dynamic Y-scale on sections query
JoshJones
JoshJones Unconfirmed Posts: 1 New Member
If there is a dramatic difference in relative base and top elevations across a series of sections, how to you automatically apply a template to a section group such that it automatically adjusts?
I.e. on any given section there is a relevant depth range of around 35m, but the absolute elevation range over which that 35m could sit is approximately 100m.
The default behavior is that the Y-axis goes from the highest to the lowest elevation, leaving excessive white space at the top, and model space at the base. I have tried this with the "auto" Y axis, but this does not seem to work.
  • ErikScheel
    ErikScheel Unconfirmed Posts: 18 Fluorite Rank Badge
    Hi @JoshJones as long as your sections are not Serial Sections, you can edit each section and adjust the centre Z coordinate to best represent where you want it to be. The template will follow:
