"Multiple Vein Intersections per hole" being ignored when selected.
Options
I have a drill hole that has two vein intersections. The hole starts in a dyke, exits for about 300 m and then goes back into it.
I have selected the "Multiple vein intersections per hole" and generated a surface. However, when I try to edit the segments Leapfrog is treating the two segments as one, creating a long 300 m segment instead of two individual segments with a HW/FW.
This vein is part of a vein system, I have used the same settings. Other veins in the system the "multiple veins per hole" button has worked as intended.
Am I missing something? The program seems to completely disregard my selection of the "Multiple vein intersections per hole" when selected.
I can't seem to find any documentation on this.
Thanks
  • Stephanie_Vanos
    Stephanie_Vanos Posts: 9 mod
    Hi GoliathResources,
    Is there any code located in the interval between the two segments?
    Generally, if you do not have anything selected between individual segments of a vein, the model will treat them as one vein segment even if Multiple vein intersections per hole is selected.
    If you select the intervals between, the problem should be fixed.
