"Multiple Vein Intersections per hole" being ignored when selected.
I have a drill hole that has two vein intersections. The hole starts in a dyke, exits for about 300 m and then goes back into it.
I have selected the "Multiple vein intersections per hole" and generated a surface. However, when I try to edit the segments Leapfrog is treating the two segments as one, creating a long 300 m segment instead of two individual segments with a HW/FW.
This vein is part of a vein system, I have used the same settings. Other veins in the system the "multiple veins per hole" button has worked as intended.
Am I missing something? The program seems to completely disregard my selection of the "Multiple vein intersections per hole" when selected.
I can't seem to find any documentation on this.
Hi GoliathResources,
Is there any code located in the interval between the two segments?
Generally, if you do not have anything selected between individual segments of a vein, the model will treat them as one vein segment even if Multiple vein intersections per hole is selected.
If you select the intervals between, the problem should be fixed.
