Spatial filter on the fly for easier viewing
In Leapfrog Works, is there a way to perform a spatial filter on the fly? The objective is to quickly reduce the number of objects in the Scene/View such that when I pivot/rotate/pan/zoom around the screen, it is better focused on the particular area of current interest (e.g., see the screenshot). Thanks for the input.
  • JoshSellars2
    JoshSellars2 Posts: 5 mod
    Hi Jackson!
    The only additional functionality (to the slicer) I might add is the Category selection tool, where you can interactively select and categorize data within a user defined area, then design a query filter to remove anything outside of that area. This would have to be done for each dataset you have in the 3D scene though, so not exactly the quick solution you were looking for.
    On that note, what you describe would be some fantastic functionality to add to Leapfrog to allow users to quickly filter spatially on the fly.
    Although the Slicer is a great tool, it is limited to one slicing plane, which is limiting when you're trying to filter the view of objects in 3 directions.
    I've added your feedback to the existing enhancement request "Improved 'slicer' (spatial filter) options in the 3D scene"
    Some of the existing feedback for this enhancement request is to enable spatial filters similar to the options on 3D Geophysical grids for all data.
    If you have any additional feedback on how you'd like spatial filters to behave within Leapfrog please let me know and I'm happy to add that.
    Best,
    Josh Sellars
  • Hi Josh,
    Thanks for the response. I'll try out some of your suggestions.
    One option for future functionality is to have different selection tools that allow a user to select certain boreholes/intervals in the scene and perform an action with them (e.g., "set all values in column X to 10" or "remove from view" or "omit from model/interpolation"); tools would be similar to those in ArcPro, like Lasso [my personal favorite], Polygon, and Rectangle. Also, the ability to add or remove boreholes/intervals from the current selection with CTRL and SHIFT without ruining the rest of the selection would be neat.
