Is it possible to rotate uploaded images in Imago Capture X?
I have already taken my rock core images and plan to import and crop them, but they also need to be rotated. I'd prefer to do it all in Imago in one shot instead of having to rotate them separately
Best Answer
  • StephanieVanos2
    StephanieVanos2 Posts: 12 mod
    Answer ✓
    Unfortunately there is no way to rotate them once uploaded. You will have to rotate them first, and then import them into Capture X, and make sure you switch the rotation option to use Exif rotation. Then they can be uploaded to the Portal and should have the correct rotation.
