Is it possible to rotate uploaded images in Imago Capture X?
SimaSaadati
in Imago
I have already taken my rock core images and plan to import and crop them, but they also need to be rotated. I'd prefer to do it all in Imago in one shot instead of having to rotate them separately
Unfortunately there is no way to rotate them once uploaded. You will have to rotate them first, and then import them into Capture X, and make sure you switch the rotation option to use Exif rotation. Then they can be uploaded to the Portal and should have the correct rotation.
Hi SimaSaadati please check our new version of Capture X at MySeequent. Rotate can be during the capture and also importing historical data using the galery at this software:
