Is it possible to filter lithology data from a drill hole by an intrusion mesh?
I'd like to visualize only the core logs within a given intrusion mesh-is this possible?
Thank you!
Best Answers
Hi @BenHenderson !
Thank you very much for the question, of course, it is possible! I leave some images with workflow that you can develop,
First evaluate (evaluation column) the data from your lithology table in the model containing the intrusion surface of interest.
Once evaluated, we are going to make a filter within the same lithology table (drillings), with the following characteristics.
At this point we select the surface (within the model) that we want to use as boundary for the filter.
It is now ready to be used,
If you have any other questions, please do not hesitate to contact us,
Thank you! Greetings!
2 -
This worked perfectly! And so simple-thank you!!!
2
1
