Error while VOXI generating
Options
Hello, Im running latest oasis montaj, and keep getting this error when generating VOXI model from polygon.
Not enough memory to create a graphics infrastructure ('OpenGL error GL_INVALID_FRAMEBUFFER_OPERATION glFramebufferTexture2D(fbo.targetO, color_attachment, m_target, m_texture, level) at M:\b\REL\ geosoft-cilgeosoft-cilgeosoft-base\core\source\geoengine.map\geoengine...:108 ' exception). Please try one of the following options: close other windows in the current application, close other running programs, increase a size of a system swap file. Other errors: Loading View failed because Object reference not set to an instance of an object.
Im running it on windows 11, on parallels pro, latest MacBook Pro with 32GB ram and M3 pro chip. I run many other graphic and other modeling/engineering softwares, never had any issue with performance.
Everything in the Montaj works perfectly smooth and fast, just the voxi keeps showing this error and is not generated. I tried different polygon sizes and resolutions and the same error always pop up.
  • Hello Marian,
    Thank you so much for reaching out and your interest in using Oasis montaj and VOXI. Please consider that we don't support MAC machines with Oasis montaj and Geosoft products. You are using Windows 11 Arm which is not supported. If you have any further questions please contact support@seequent.com.
    Regards,
    Farzaneh Farahani,
    Project Geophysicist
  • Thanks, Its already working, just needed to turn on software rendering in the Oasis montaj Advanced settings :)
