Two Identical Slope/W Models Returning Different Factors of Safety
I have two approximately identical slope/w models of an existing earthen embankment dam with different factors of safety. Both models consider a failure of the upstream slope of the embankment. The only difference between the two models is how the approximately same phreatic surface is input.
"Model 1" has a phreatic surface defined by a parent seep/w analysis and "Model 2" is a clone of "Model 1" that has a piezometric surface manually defined by a coordinate-traced-copy of the phreatic surface developed by the "Model 1" seep/w parent analysis. "Model 2" does have a slightly lowered phreatic surface near the midslope of the downstream slope (to represent a proposed drain), but I don't believe this should affect the pore water conditions in the slip surfaces since the failure is of the upstream slope where the phreatic surfaces for both models are essentially equivalent.
I've printed the model report for both models and can confirm that all other inputs are the same (side function, slip surface optimization, entry and exit points, convergence settings, materials, etc.). "Model 1" has a factor of safety that is three tenths (0.3) higher than "Model 2". Does anyone have any insight as to what could be causing this discrepancy?
Thanks
  • Hey Trevor, I see the different equipotential lines in each of my two models — makes sense. Thanks for the response and detailed explanation!
  • TrevorKent
    TrevorKent Employee Posts: 48 Topaz Rank Badge
    Awesome! I'm glad I was able to clear that up for you.
