Anchor Support: Red box in front of slip surface
When I run my stability analysis with an anchor, it is showing that the support from the bonded zone is in front of the critical failure surface (as shown by the red box). When I make the anchor longer, this support goes away, which seems to me the opposite of what should happen. What is going on?
  • Hi Erik, thanks for reaching out in the Seequent Community. That is very strange. Would you mind emailing support@geoslope.com with your model attached and your serial number so I can take a closer look? Thank you.
