SEEP - Comparing groundwater scenarios, with/without excavated shaft
Hi
I have created two steady-state 2d groundwater models without and with an excavation and a drainage layer. I would like to compare these and get the difference in water levels/pressure. I cant really seem to find any way to do this so I would really like to hear from the expertise here.
Best regards
  • TrevorKent
    TrevorKent Employee Posts: 52 Topaz Rank Badge
    Hi Robin,
    Thank you for your question. In the Results view, you can create graphs of different parameters at the locations you choose and view contours right on your domain. You can export the graph data so you can easily compare them. Do these tools serve your purposes?
  • Hi
    Thanks for the answer. That takes me halfway there, but it would have been interesting to do a comparison akin to comparing rasters to get the whole picture. But if that is not possible then I might have to rethink how I calculate this or how to show the results.
