Coupled Sigma W and Seep W
AliShokouhi
in GeoStudio
Hi,
I am modelling construction of a capping layer on top of the tailings. I use saturated model for tailings and unsat model for capping material. When I applied the first layer of capping layer, I get another water table at the top like a perched water table. I even use very low activation PWP and compressibility for capping, but the problem is not solved.
Hello Ali, in order to fully understand your question, it would be helpful to see your project! Please send it to: support@geoslope.com
0 -
Hi
Was there a solution found for this? I am seeing the same issue with seep and sigma being coupled. The fill material placed on top of the ground surface (analyzed in in-situ analysis first) develops phreatic line. The fill has 3 materials (clay, filter, riprap). The phreatic line develops in all three materials. We have even tried placing a seepage face on the ground surface (below the fill material).
We have already opened a ticket for this: E-VM00014356Thank you
0 -
Hi Arjan, just following up to confirm that the issues were mainly due to unconverged results. Thanks!
0 -
Hi Kathryn
Yes. Thank you.1
