How to control the initial saturation degree in transient analysis
Hello.
I'm conducting a transient analysis to simulate the infiltration of runoff into a sump, but I'm encountering convergence issues. Despite trying all the suggestions from here, here and here ,
I continue to see red crosses in few steps (day 45-48). Upon reviewing my model, I noticed that the transition in saturation occurs too rapidly and drops to about 0.18, whereas I would expect it to be closer to 0.80. Could this be the source of the problem? With this saturation, it leads to a permeability in the order of -12, which is not what I expect from the material. Should I change the Maximum Suction from 1000 kPa to something else?
During my research, I came across the activation of the PWP (Pore Water Pressure) function within the material settings, which I'm not currently using. I suspect I might be missing something here. However, I haven't been able to fully understand this function or how to implement it. Are there any resources available on this topic? Could someone provide guidance?
Thank you!
Hi Jeniffer, this sounds like a question for the GeoStudio technical support team! Can you email support@geoslope.com with your model attached so we can assist you better?
Categories
- All Categories
- 6 Community
- 3 Get Started
- 16 Latest Releases
- 15 Member Spotlight
- 40 Learning
- 2 Products
- 1 Geology
- 535 Leapfrog
- 1 Volsung
- 26 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- Geotechnical
- 136 GeoStudio
- Geophysics
- 319 Oasis montaj
- 1 Workbench
- SPIA
- 9 Res2DInv & Res3DInv
- 3 Evo
- 26 GX Developer
