Can a Voxel 3D model be intercepted with drillings?
DouglasPerez
in Leapfrog
I'm trying to get a new column in my drilling database. This column is for data from voxel 3d model for example:
What I want is
Hole ID / from / to / lithology / magnetic susceptibility / NEW DATA FROM VOXEL MODEL
Currently I have everything except the DATA FROM VOXEL MODEL.
I really appreciate if someone can help me
Hi, I can help you, the first action are:
- create the planned Borehole
- Selection Prefix > Click in (+)
- Selection the ubication the new borehole (two options: Specify > Collar or Target (the diference is in Collar you defined the Depth in Target Leapfrog autimatically calculates the Depth value)
- When after create the new borehole you can be evaluated against any models in the project
I copied a Link where you see the instructions about the planned borehole data.
LINK:
1 -
Thanks for your answer.
Do you know if I can use my own drillings?0
