Calculating depth array from elevation array
Hello.
At some point in the past I recall being able to calculate a depth array using channel maths by subtracting the elevation array channel from the ground surface elevation. This doesn't seem to work today. Does anyone know if i imagined this or if it is possible now?
Many thanks
Tim
Best Answer
  • ElizabethBaranyi3
    Answer ✓
    Hello Tim
    You can do this. Here are the steps :
    Copy your input array to the output array, to generate another array with the same dimensions.
    Database tools>Channel Tools>Copy Channel
    Then run Math Tools
