Calculating depth array from elevation array
TimNixon1
in Oasis montaj
Hello.
At some point in the past I recall being able to calculate a depth array using channel maths by subtracting the elevation array channel from the ground surface elevation. This doesn't seem to work today. Does anyone know if i imagined this or if it is possible now?
Many thanks
Tim
Hello Tim
You can do this. Here are the steps :
Copy your input array to the output array, to generate another array with the same dimensions.
Database tools>Channel Tools>Copy Channel
Then run Math Tools
Thank you so much! Really appreciate the answer.
- 287 Community
- 563 Geology
- 536 Leapfrog
