What is G (equivalent) in QUAKE/W module?
Hi!
Thank you so much for your post
G equivalent, in the equivalent linear model, is a value that changes in every iteration by a function and uses as parameter Gmax.
The Equivalent Linear model is very similar to the linear-elastic model. The difference is that the soil stiffness G is modified in response to computed strains.
With the Equivalent Linear model QUAKE/W starts a dynamic analysis with the specified soil stiffness. QUAKE/W steps through the entire earthquake record and identifies the peak shear strains at each Gauss numerical integration point in each element. The shear modulus is then modified according a specified G reduction function and the process is repeated. This iterative procedure continues until the required G modifications are within a specified tolerance.
If you have any more questions, please feel free to reach out!
Cheers!
Categories
- All Categories
- Community
- 16 Latest Releases
- 15 Member Spotlight
- 38 Learning
- Products
- Geology
- 535 Leapfrog
- 1 Volsung
- 25 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- Geotechnical
- 136 GeoStudio
- Geophysics
- 319 Oasis montaj
- 1 Workbench
- SPIA
- 9 Res2DInv & Res3DInv
- 3 Evo
- 25 GX Developer
