How can i change the number of decimal places on an entry in my legend on a section?
I'm creating a cross section with a block model of a mag survey (discrete colourmap). My values are all quite small (3 decimal places) but the legend on the section will only display whole numbers. I can't see where I can add decimal places.
Thanks for any help!
Best Answer
  • CarlyThorpe1
    CarlyThorpe1 Posts: 20 mod
    Answer ✓
    Hi @MargotDupont2
    In the latest version 2024.1.1 you can set the decimal places in the label settings up to a maximum of 4 decimal places. If you are not using labels these can be switched off once the decimal places have been set.
  • CarlyThorpe1
    Hi @NathanCronin1
    That is a known limitation with the cross-sections and will be fixed in a future release. Sorry for the inconvenience. In the meantime, you can convert the numeric field into a category column using the same cutoff values. The category labels are fixed so you can put as many decimal places as you need.
    Thanks
    Carly Thorpe
    Senior Project Geologist
    Seequent
  • Thanks for the response, Carly. I ended up just using illustrator to adjust the pdf's once I exported them, but the category field would be a good work-around as well.
  • @CarlyThorpe1 Do you have any news on when this issue will be solved? It's been almost a year.
  • Thanks @CarlyThorpe1 !
