How can i change the number of decimal places on an entry in my legend on a section?
I'm creating a cross section with a block model of a mag survey (discrete colourmap). My values are all quite small (3 decimal places) but the legend on the section will only display whole numbers. I can't see where I can add decimal places.
Thanks for any help!
In the latest version 2024.1.1 you can set the decimal places in the label settings up to a maximum of 4 decimal places. If you are not using labels these can be switched off once the decimal places have been set.
2
That is a known limitation with the cross-sections and will be fixed in a future release. Sorry for the inconvenience. In the meantime, you can convert the numeric field into a category column using the same cutoff values. The category labels are fixed so you can put as many decimal places as you need.
Carly Thorpe
Senior Project Geologist
Seequent
Thanks for the response, Carly. I ended up just using illustrator to adjust the pdf's once I exported them, but the category field would be a good work-around as well.
@CarlyThorpe1 Do you have any news on when this issue will be solved? It's been almost a year.
Thanks @CarlyThorpe1 !
