CANNOT INSTALL OASIS MONTAJ 8.4 ON WINDOWS 11
I have been trying to install an Oasis Montaj Desktop Application on Windows 11.
Anytime I run the installer, the interface that pops up just stays blank and never installs.
I have tried troubleshooter and tried running in compatibility mode and also ran it as an administrator but same issue persist.
  • IgorSram1
    IgorSram1 Posts: 8 mod
    Hello James, Oasis montaj 8.4 is not supported on Windows 11. Suggest upgrading to Oasis montaj Desktop Applications 2022.1 or higher if you want it to work on Windows 11.
  • Thank you.
    I've been able to solve the challenge though
  • Hey James how did you resolve the problem?? I equally have the same challenge on windows 11
  • Hi Abraham,
    Just change the contrast of your PC display
    Select the Start button, and then select Settings > Accessibility > Contrast themes. To turn on contrast themes, select the theme you want from the Contrast themes drop-down menu, and then select the Apply button.
    Try several options of contrast till you find one that suits you
  • I tried the above procedures but not success
  • JoeMcPherson1
    JoeMcPherson1 Posts: 3 mod
    Hello All,
    It's worth mentioning that Oasis montaj 8.4 was developed and tested on Windows 7 SP1 (32& 64), 8, and 8.1 (32& 64). It is not supported on Windows 11. While it may work, it's likely that you may run into some issues.
    8.4 was also retired several years back when we upgraded to Seequent ID licensing. To read more about our Desktop Software Version Support Poilicy see: https://www.seequent.com/help-support/desktop-software-version-support-policy/
  • JoeInman
    JoeInman Posts: 7 Corundum Rank Badge
    I have OM 9.3 installed on Windows 11 and I must say my 9.3 is working better than ever. In case anyone wants to know.
  • I interesting of oasis montaj 9.3 of Joelnman
