Can drillhole traces be coloured by fields in the survey table, e.g. survey method?
RichardHingston
in Leapfrog
I want to colour my traces by survey method to
see what has PLAN data v what is GYRO. However, the survey table has no functionality
in terms of being able to display the data within.
Does anyone know a workaround within LF for this? Or do I need to pre-code it into the collar (or another 'displayable') table outside LF?
1
You can't colour the traces by any attribute. Instead you would need to manually adjust the survey file in Excel so that you have an interval file with froms an tos. Then import this to LF as an interval file using the survey method column as a category.1
I would try the same way
Categories
- All Categories
- Community
- 16 Latest Releases
- 15 Member Spotlight
- 38 Learning
- Products
- Geology
- 535 Leapfrog
- 1 Volsung
- 25 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- Geotechnical
- 136 GeoStudio
- Geophysics
- 319 Oasis montaj
- 1 Workbench
- SPIA
- 9 Res2DInv & Res3DInv
- 3 Evo
- 25 GX Developer
