Regarding the geologic contacts on the surface
Options
RaymondMartinMagalon
in Leapfrog
Hi Raymond
To create your contacts proceed as follows:
The first step is to create a horizontal plane using the command Create a Mesh by Moving Plane at the Meshes Folder. This plane has to be on a reasonable elevation that's permits cuts the litologies.Now you could generate this lines (contacts) by an intersection of the mesh lithologies with this horizontal plane, using the command: New GIS Line> From Intersecting Mesh, in the GIS, Data, Maps and Photo folder in Leapfrog.
After create these GIS lines, (that represent your contacts), you could project them on topography.
Regards0
