old project review
STEPHENDIXON
Posts: 1 New Member
in GeoStudio
Hello all. How can I review an old project (inputs and geometry and results)? Is it possible with a student license?
Hi Stephen, you should normally be able to open an older GeoStudio file with a recent version. The software will automatically upgrade the old file to the current standard to the best of its ability. The software will then notify you if some changes require your attention (because the changes from the old to the newer version was drastic for example).
Student licenses have quite limited functionalities so you might run into issues there. Most universities have a few GeoStudio licenses, you might be able to get one if you ask for it.0
Categories
- All Categories
- 311 Community
- 3 Get Started
- 18 Latest Releases
- 17 Member Spotlight
- 42 Learning
- 1.1K Products
- 567 Geology
- 540 Leapfrog
- 1 Volsung
- 26 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- 138 Geotechnical
- 138 GeoStudio
- 334 Geophysics
- 323 Oasis montaj
- 1 Workbench
- SPIA
- 10 Res2DInv & Res3DInv
- 3 Evo
- 27 GX Developer
