Can a section layout be created from a cross section image?
I created a new cross section from image using a seismic image. I want to be able to create a section layout using that cross section and have the seismic image scaled appropriately so that drill holes can be projected onto the seismic image/section layout but the seismic image doesn't show up on the layout. Is there a way to do this? The only way I see I can add an image is under comments as a static (unscaled) image.
  • DavidWatkins
    DavidWatkins Employee Posts: 48 mod
    Thanks for the feedback @ChristineDevine,
    I will add a feature request for that functionality on your behalf.
    The only workaround that I can think of is to view both the image and section layout in the 3D scene and then create a cross section to limit the data shown and render the scene to an image. Not the most elegant solution but perhaps a stop-gap solution to get what you need for the meantime.
    Regards,
    David
  • I'd also like to include geophysical data in section views so keen to 'upvote' this functionality request.
    Thanks
  • DavidWatkins
    edited July 2021
    Upvote added to the feature request @MichaelBlakely. Thanks for the feedback!
